Re: 350 U wheel stuck
Posted by Brownie450 on September 07, 2007 at 05:33:01 from (207.177.82.67):
In Reply to: 350 U wheel stuck posted by TomA on September 07, 2007 at 01:39:13:
Brakes are a good place to start. Our 450 sounded like a rear wheel bearing was locking up intermittently. Welllll---we went to the trouble of pulling the rear axle-- only to find the problem was one of the 3 brake retracting springs on the brake discs had rusted a hook off, & dropped down to the bottom of the brake casting. Amazing what a spring can do in the way of making noise & even nearly stopping the tractor while on-the-go. Hope this helps. May save an axle pull.
