Thank you very much for you reply. I did polarize the generator. One wire connects to the "Bat" terminal. Where would the second wire connect to? The "l" terminal is the only terminal not being used. Terminals "A" and "F" are connected from the voltage regulator to the generator. The "bat" terminal is connected correctly, I believe. My manual does not have a diagram that shows the wiring for a Farmall H with a distributor; however, it does show the wiring diagram for the Farmall H with a magneto. Any further suggestions you can give me would be greatly appreciated. monty
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
