Posted by CNKS on September 09, 2007 at 16:12:50 from (216.144.104.128):
In Reply to: 1947 and 1952 Farmall posted by Monty S. Frazier on September 09, 2007 at 14:49:12:
Someone else will give you a detailed wiring diagram for battery ignition. I use the one in the operator's manual. Your generator needs to be polarized, and you MUST use both connections. If the dealer put a cutout relay on your generator the low, high, dim, bright switch works as it always did. If he installed a voltage regulator L and H are the same.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
