Re: 1947 and 1952 Farmall
Posted by r4etired on September 09, 2007 at 16:54:05 from (205.188.116.73):
In Reply to: 1947 and 1952 Farmall posted by Monty S. Frazier on September 09, 2007 at 14:49:12:
Try grounding your front lites to a good ground, I have found grounding is a big problem.Sometimes it is in the clamp on the light,sometimes at the U bolts holding the light bracket and I had one it was at the base of the steering support, I,m taking for granted your bulbs are good
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
