Posted by Monty S. Frazier on September 09, 2007 at 14:49:12 from (209.215.22.140):
I have a 1947 Farmall H. I replaced the magneto with a distributor. It is still running on six volts. I pulled the generator and had it serviced and the guy put a new 6 volt saddle mount on the generator. The tractor uses the l h d m switch system. The tractor is not charging the battery and I think the lights are running off the battery. When I pulled the magneto, the wiring harness running to the generator has two leads. One is for the battery and the second one I taped off. Any suggestions would be appreciated where my problem may lay.
I have also a 1952 Super M. The rear light is working but the two front lights are not. Does anyone have any suggestions on what the problem may be. Thanks Monty
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
