Re: electronic Ignition
Posted by John T on September 10, 2007 at 07:27:49 from (66.244.83.147):
In Reply to: electronic Ignition posted by Tom Lee on September 10, 2007 at 07:00:12:
Its your call. They are around $100 or less and HOPEFULLY N THEORETICALLY LOL will outlast many many sets of $25 or so points n condensors???
HOWEVER if you (as I strongly recommend) couple the elec switch with a matching high energy high voltage coil n run a wider plug gap youre gonna end up with much more spark gap energy n a hotter spark across a wider gap to better ignite the fuel then a stock points n condensor ignition PERIOD. Buttttttt unlike a set of burned points where if stuck in the field you might file the points n get back home, if the elec switch fails YOURE DEAD GRRRRRRRRR
Your tractor your choice
John T
