sounds like the lower crankshaft pulley seal is leaking. pretty sure you need to remove the front bolster with eth front wheels and radiator ect to get at the lower pulley. use a gear puller or bearing splitter to get the pulley off, then you will see the seal. seal should pop right out, and new one drives in. check the pulley surface to see if there is a groove worn in it from the seal, if so, you can get a speedy sleeve from berry bearing, and install that, and you are good to go.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
