Re: Farmall B - carb
Posted by Janicholson on September 10, 2007 at 08:41:24 from (199.17.6.122):
In Reply to: Farmall B - carb posted by Dave H (MI) on September 10, 2007 at 08:06:30:
Air in a gravety fuel system can only happen when the tank is empty! Try the adjustment now to see if it will richen up. A 2% blockage in a passage can affect 20% of flow! Things are good. Get used to:
Shutting off the fuel valve every time it is stopped for a few minutes.
Learning the choke operation over ambient temp and engine heat variations. It will start well. JimN
