Farmall 300 TA Question
Posted by Medina Farmer on September 10, 2007 at 09:38:10 from (207.69.137.7):
I had the Clutch replaced a few years ago. And about a year ago the TA was slipping in hi. All of the gears would slip.
Then I heard a click or noise and was able to use all the gears in TA low. I did not use or move the TA at all. Just kept it put. Used it for a year.
Then like a dummy I put it in high gear and it slip out. So it slips now in all forward gears. I was told it must be the TA since the clutch is new.
I read most of the forums on TA and looked at the adjustments. All the TA adjustments seem to be correct.
I was wondering if someone might know what might be wrong. The TA only worked on the low side but now it spins in all forward gears.
Any help would be appreciated. And if you recommend the TA repair video?
