Re: Farmall 300 TA Question
Posted by GD720D on September 10, 2007 at 15:39:02 from (66.226.101.80):
In Reply to: Farmall 300 TA Question posted by Medina Farmer on September 10, 2007 at 09:38:10:
If T.A. holds on low side the Ta is okay. I would suspect is out of adjustment on the small TA clutch that has to hold when the TA lever is forward. I would get somebody that knows how to adjust the TA. and make sure there is clearance between the fingers on the small pressure plate and the throw-out bearing when the lever is forward.If the small pressure plate was replaced when the TA was put in check the pressure plate some after marketers put three small bolts in the plate to keep it released when putting in the tractor. It these aren't removed the tractor will slip in all gears with the lever forward. Have worked on three tractors that had this problem where somebody goofed.
