Posted by Peabody on September 10, 2007 at 13:17:33 from (66.168.232.149):
In Reply to: C and hydrolic pump posted by Johnny D on September 10, 2007 at 13:07:50:
There is no gasket between the pump and the engine. Your problem is most likely the seal on the pump shaft, which allows fluid to enter the engine oil pan. A rebuild kit is available and will probably solve the pump leak also. It's an easy fix. I'm not sure what this would have to do with an indicated drop in oil pressure, though.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
