C and hydrolic pump
Posted by Johnny D on September 10, 2007 at 13:07:50 from (65.183.107.231):
I noticed the C i bought was about 4 quarts low of hydrolic fluid. After filling to required level and running her for while my oil pressure started to drop a little at a time. What was happening according to the old guys is that the hydrolic fluid was being pushed into the oil. It also has a bad leak on the hydrolic unit itself. No visible leaks on the pump. I was told that most likely I would need to replace the gasket that is between the hydrolic pump and the engine to stop if from leaking into the oil pan. And it looks like i need to rebuild the hydrolic unit as well to stop the exterior leak on it. Any other helpful information is appreciated.
