Posted by georgeky on September 10, 2007 at 13:24:35 from (64.12.116.73):
In Reply to: C and hydrolic pump posted by Johnny D on September 10, 2007 at 13:07:50:
Johnny, there is a seal in the front of the pump that is bad. The shaft may also be worn and need a speedy sleeve put on it. Use only sae 30 weight oil in the hydraulic system until you get this fixed. Hydraulic oil is to thin for the engine. Seal and gasket kits are available from IH. There are 3 different pumps it could be so you need the part number from pump when ordering kit. The lift unit itself has a kit available for it as well. Keep it clean and lay all parts out in order they come out. Makes putting back together a lot easier. Get an IT No IH-8 service manual as it will be needed for proper adjustment of the lift unit. Not real hard to do, but cleanliness and proper adjustments are critical. Call Brad Marshall and he will send the parts you need right to you. 1-888-824-0544.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
