Re: SuperC - axle bearing question - will this work?
Posted by Randy in NE on September 10, 2007 at 14:09:11 from (204.124.192.31):
In Reply to: SuperC - axle bearing question - will this work? posted by keithf on September 10, 2007 at 13:50:40:
You can take the bearing number to any good shop and get them cross it. I had to do that and the only bearing that matched the ID and OD was sealed. I just removed the thin sheet of tin so that it would get lubricated by the rearend grease. I ended up getting mine at a White-Freightliner truck dealer.
