Re: SH with H engine
Posted by RustyFarmall on September 10, 2007 at 14:37:08 from (66.43.253.55):
In Reply to: Re: SH with H engine posted by nspec on September 10, 2007 at 14:00:59:
If the choke lever is on the inside, most likely it is a Super carb, but the super Ms, 300s, 350s, 400s, and 450s also had the choke lever on the inside. I know of several Hs with the 152 engine that are now using the bigger carb such as found on an M, and they all run just fine.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
