1947 Farmall H Replaced Magneto With Distributor
Posted by Monty S. Frazier on September 10, 2007 at 18:11:01 from (216.78.83.9):
Thank you very much for you reply. I did polarize the generator. One wire connects to the "Bat" terminal. Where would the second wire connect to? The "l" terminal is the only terminal not being used. Terminals "A" and "F" are connected from the voltage regulator to the generator. The "bat" terminal is connected correctly, I believe. My manual does not have a diagram that shows the wiring for a Farmall H with a distributor; however, it does show the wiring diagram for the Farmall H with a magneto. Where would I connect the second wire to? The only opening left is the "L" terminal. What is the "L" terminal used for? Any suggestions you can give me would be greatly appreciated.
monty
