Re: farmall Hmax pull
Posted by Andrew Z on September 11, 2007 at 18:25:48 from (12.76.132.71):
In Reply to: Re: farmall Hmax pull posted by Pat-CT on September 11, 2007 at 18:15:22:
Well if your loooking to pull stone boat we pull a good amount of weight there and is more of a "power pit" however there we have 4000# class that you can get your H into. I pull my H in that class at a few pulls and i can stay with them. My H is 100% stock with nothing done to it. If you take those weights off you should be right there! I have the hydor pump still and belt pully still on mine and i make it. My father pulls his Super H in 4500# but its like two times the tractor. and I pull a Allis B in 2500#. If you want to pull the transfere if your tractor is stock then it will be alittle lite on power. It all depends on what you want to do, either way its good to see a new puller out there!
My Email is open if you have more Q's
Thanks
Andrew
