Re: reversing the fan blades on a 574
Posted by chadd on September 12, 2007 at 05:23:25 from (155.92.33.38):
In Reply to: Re: reversing the fan blades on a 574 posted by Bob M on September 12, 2007 at 04:18:19:
I've been in his situation, too. Cutting hay with our 2500A is the same thing (I suppose it would be, it is the same tractor). When our 806 went down, I had no choice but to use it. I would do the outside round and the grille was plugged full of garbage. Ours already has window screening in the grille. It still manages to get it through it and plug up the oil cooler. After you put the screening in, you will still have to get off every round and clean it off, but now it is mostly the grill (which you can bang against your leg), and not the radiator. This is one area where the extra height of the Farmalls have the standards and utilities beat. I haven't had to clean out the 806, 966, or M yet this year.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
