Re: reversing the fan blades on a 574
Posted by Bob M on September 12, 2007 at 04:18:19 from (151.190.254.108):
In Reply to: reversing the fan blades on a 574 posted by johns48jdb on September 12, 2007 at 03:58:58:
Turning the fan blade around won't work!
Only way to reverse the airflow thru the radiator is to replace the existing fan with a "pusher" fan.
Keep in mind however for your plugging problem, using a pusher fan will cause the trash to now collect on the engine side of the radiator - where it's more difficult to clean out.
Suggest instead wrapping the grille front with common window screen, then periodically brushing the collected stuff off while 'hogging.
I did that to our Oliver 1650 for 'hogging - it works great.
