Posted by JT on September 12, 2007 at 06:09:47 from (70.226.232.184):
In Reply to: Smokin' H posted by Minnesotan H on September 11, 2007 at 19:13:34:
One thing I have had good luck with to unfree stuck rings from sitting is Sea Foam. You could put 5 gallon of gas in the gas tank, add a whole can of Sea Foam to that, then take another can, put it in a squirt can, take off the intake tube, start tractor, let it warm up a little, 5-10 minutes to get heat in engine, run at about 1000 rpm or so, the start pumping the Sea Foam into the carb throat with the squirt can, and do it fast, put enough into the carb throat to flood and kill the engine. Let it sit for 3-4 hours or more, start, run engine, then go out and use it. If it is going to straighten out and run right without and overhaul, this should do it. What you describe is rings stuck in piston from sitting, and needs the carbon softened up so it can blow out, As Allan said, that thing is over 50-60 years old, and if it is original, it may be time for a rebuild. But, try the Sea Foam thing, I have had luck with that on small engine that have sat or have issues with carbon. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
