This is a very common problem on anything with a Roosa-Master pump that has several thousand hours on it. There are two seals on the injection pump driveshaft, one to keep engine oil out of the pump, and one to keep fuel out of the engine oil. Get yourself an I&T manual, and you should be able to remove and reinstall the pump yourself. I would recommend taking the pump to a pump shop at that point, as the seals can be a little touchy to install without a couple special tools.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
