Re: f-30 engine
Posted by F-Dean on September 13, 2007 at 18:16:21 from (67.72.98.84):
In Reply to: f-30 engine posted by wegman in mn on September 13, 2007 at 16:10:20:
You might make it work if you take the rails from the F-30 and bolt them onto the F-20 transmission. However, you will also have to switch the gas tank and steering wheel mount to account for a taller engine. By now you may have lost any weight advantage!
