Posted by Mike CA on September 16, 2007 at 08:46:16 from (75.31.162.209):
In Reply to: Gastank pads posted by RustyFarmall on September 16, 2007 at 04:25:08:
RustyFarmall said: (quoted from post at 04:25:08 09/16/07) Those pads are available from a variety of sources as are the radiator mounting pads. You can make them yourself, but if the material chosen is not of the correct thickness, you will encounter problems with the hood not fitting correctly, or in the situation with the radiator, the steering shaft could end up interfering with the hole that it passes through.
hmmm, very good point to consider Rusty. The previous set up were home made pads under tank and the radiator, and the fit of the grill/hood/tank was off just a bit. I didn't understand that could affect them like that. Knowing that, I will go with the aftermarket replacements.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
