Farmall Super A magne to vs distributor 12 volt conversion
Posted by Russ Crawford on September 16, 2007 at 08:57:59 from (207.200.116.7):
I am restoring a Farmall Super A. I have two questions. 1) the tractor currently has a distributor I am thinking of changing to a mag . Will a mag from a modelB fit? Is this a good Idea? 2) The tractor has been converted to 12 Volt. I an not sure it was done correctly. Where can I get detailed instructions on how to change from 6 to 12 volt system. Any help will be appreciated Thanks Russ
