Re: letter series Farmall
Posted by CNKS on September 16, 2007 at 17:22:37 from (216.144.104.128):
In Reply to: letter series Farmall posted by chuck craig jr on September 16, 2007 at 17:10:52:
The bigger the tractor, the more power. For a rear blade either will do, although the M is probably overkill. If you are going to get a front loader, avoid the C as it does not have frame rails and is easier to damage. For what you want to do the H is probably ideal -- you will need an add-on 3 point for the blades on all of them, though. You can build a front mount blade -- I don't know if any are commercially available.
