I have a C-153 in a combine, which is kinda like the C-135's big brother. With new 30W oil, I saw a little over the middle line on the gauge, which I believe is approximately 40 psig. At wide open throttle it was about 55 to 60 psig(not quite 6 lines from zero). With the old oil that was extremely thinned out from use, it was about 25 psig at idle and about 40 psig at wide open throttle. If I remember correctly from the owners manual, the minimum pressure for engine lubrication is above 2 lines from zero on the IH gauge at 200 rpm above idle. The combine doesn't have a tachometer, so that doesn't help me much. . .
Unfortunately, from what I have heard, these motors, when aged, tend to display low oil pressure problems relating to cam bearing wear. Also unfortunately, all cam supports but the front are bored directly in the block. If they are worn, either the block is junk or you will need to have the holes overbored and have custom made bushings pressed in. I have no idea what pressure that pressure sending unit requires, so you will have to hook up a gauge to find out what you have.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
