Re: 404 C135 oil pressure?
Posted by ShaggyM on September 17, 2007 at 11:29:21 from (12.208.44.28):
In Reply to: 404 C135 oil pressure? posted by JSharp on September 17, 2007 at 09:36:12:
It could be your oil pump. There is a thin paper gasket between the cast body of the pump and the pot metal (or aluminum) bottom. These gasket blow out sometimes and you need to get the pump out and take the bottom off and flatten it out and replace the gasket. You oil pressure should be better.
