Posted by bc on September 17, 2007 at 11:41:38 from (69.148.26.111):
Hi, I have the backhoe/loader that corresponds to an Ind 606/2606. I know from earlier posts that it may be the same as a 460 utility or a 504/2504.
I have a problem that the direction reverser pops out of gear going forward. I have to hold it sometimes with my knee. Reverse is not a problem. The linkage seems to pop it into forward and reverse with some play to spare so it isn't a linkage adjustment issue. It does it when I start forward and then throttle up the engine for speed. Any ideas? I hope I don't have to put another bungee cord on it to hold in gear. Thanks.
Although possibly unrelated, I suspect I may have a clutch issue. Sometimes it shifts with no gear grind and sometimes it wants to exhibit some gear grind as iff there is a synchronizer problem assuming these transmissions have synchronizers although gear grinding used to be normal for old transmissions. When I got it, there was no return spring on the clutch pedal. It just put its weight down on the clutch but it does disengage when pressed another inch or so to the floor. thanks.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
