Re: more 354 troubles
Posted by glennster on September 17, 2007 at 11:47:13 from (76.224.21.81):
In Reply to: more 354 troubles posted by WVhogleg on September 17, 2007 at 11:27:59:
either there is a restriction in the fuel tank or lines, or the carb is plugged up. remove fuel line from the carb and see how it flows, let it run a while into a can. if you have good flow, drop the bowl off the carb and look inside. could be full of junk.
