Re: How loose can a dry sleeve be?
Posted by Mike Farmer on September 17, 2007 at 11:54:05 from (81.107.136.160):
In Reply to: Re: How loose can a dry sleeve be? posted by El Toro on September 17, 2007 at 11:24:46:
Within sensible reason(more than hand tight) providing it is not letting water leak into the oil sump/pan
