Re: How loose can a dry sleeve be?
Posted by Janicholson on September 17, 2007 at 13:47:07 from (199.17.6.122):
In Reply to: How loose can a dry sleeve be? posted by Uncle Fester on September 17, 2007 at 10:09:24:
The sleves crack at the rim and are sucked down into the rod area just a bit, then the rings pop out into the gap and it is sucked into violent decomposition. The book is correct. A sleeve (cold as a freezer will make it) should slip in about i/4 to 1/3 the way then require either block of wood pounding with a two pound hammer, or a sleev installer. Bores are lettered in most tractors next to the hole A B C D. If you have a C or D hole, the aftermarket sleeves will likely be loose. Do not believe plastic will conduct heat well it does not. JimN
