Re: Farmall B Govenor bearings for block and end shaft
Posted by gene bender on September 18, 2007 at 03:29:31 from (67.55.226.214):
In Reply to: Farmall B Govenor bearings for block and end shaft posted by Gerald Peterson on September 17, 2007 at 20:18:45:
Do you mean the bushing in the block where the gov gear goes or the three piece little bearing that goes on the shaft where the weights push. They are both avail. If you cant find one i can send you one as i get them from my I-H dealer.
