Re: Primer ????
Posted by Wardner on September 18, 2007 at 19:06:31 from (4.154.240.128):
In Reply to: Re: Primer ???? posted by CNKS on September 18, 2007 at 18:49:03:
One of the DuPont epoxy primers is Corlor 825S. It is "high build" and sandable. The Corlor name is also used with a single component primer which I don't think is suitable for surfacing.
The two part is great for filling rust pits. You can "lay it on" using a narrow fan and minimal thinner. I usually heat it up to get it out of a siphon gun.
I used to buy both products by the pallet. I was using the industrial grade but it is also formulated for autobody.
Here is a little tip. If you mix an excess amount of the two part epoxy Corlor, you can put it in the freezer and it will go into a "coma" indefinitely. Months later you can thaw it out and it will perform as intended.
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
