Re: Electrolysis revisited again
Posted by Haas on September 19, 2007 at 05:34:25 from (12.65.6.157):
In Reply to: Re: Electrolysis revisited again posted by scott#2 on September 18, 2007 at 19:49:45:
Be careful with that!! Should be done only in very dilute solution like the electrolysis solution. Sulfuric acid and Lye are both very corrosive agents and will cause big problems if you get them on your skin. If the solution is concentrated, a lot of heat will be generated and the result could be a violent reaction. The end result is a solution of Sodium Sulfate, not common salt. Better to just find some soda ash which is much safer.
