Re: More Sleeve Issues
Posted by K.B.-826 on September 19, 2007 at 17:50:46 from (68.115.101.91):
In Reply to: More Sleeve Issues posted by Uncle Fester on September 19, 2007 at 16:36:23:
Almost sounds like the deck of the block is warped. The correct fix would have been to have the block machined flat and then have the counterbores machined. I think you may be a little too far in to turn back now, unless you can remove the sleeves that you loctited.
