Re: More Sleeve Issues
Posted by Uncle Fester on September 19, 2007 at 18:50:28 from (4.252.157.224):
In Reply to: Re: More Sleeve Issues posted by K.B.-826 on September 19, 2007 at 17:50:46:
I checked the block and it is flat as a pancake, however, upon further inspection I discovered that all four of the sleeves are slightly higher on the same side but three of the four don't go below the deck. It appears that the deck was cut at a slight angle to the bores. The engine ran well for years and didn't leak so I will go with the shims to raise the one sleeve that dips into negative territory. Interesting.
