Re: H rim size
Posted by Steven f/AZ on September 20, 2007 at 07:36:23 from (216.67.213.217):
In Reply to: H rim size posted by Mike CA on September 19, 2007 at 21:04:50:
Both my H"s have 12.4x38 tires on them and they are a good fit for an H and look "right" as far as size goes.
I don"t have any trouble with traction, either. Plenty of bite for the power of an H under normal conditions. I don"t run fluid, either.
A 10" or 11" wide rim should work fine on your H.
Pics of my Hs with 12.4x38
