Re: Super A 6 vollt or 8 volt
Posted by Bob on September 20, 2007 at 07:47:04 from (69.178.229.154):
In Reply to: Super A 6 vollt or 8 volt posted by ram4wd on September 20, 2007 at 07:41:27:
That little tractor will start just fine on 6-Volts, IF the starter, generator, and battery are good, AND all the electrical connections are "clean, bright and tight".
Installing an 8-Volt battery without setting up the charging system REALLY doesn't do much good, as all you will have is a partially-charged 8-Volt battery.
