Super A 6 vollt or 8 volt
Posted by ram4wd on September 20, 2007 at 07:41:27 from (160.93.195.27):
Good Morning,
I need to replace the battery in my 1948 Farmall Super A. The man at Tractor Supply Co. suggested an 8 volt battery for better starting. my question is would it burn out the lights and would the generator and regulator be affected with an 8 volt battery? thank you for your help
Bob W.
