Re: Super A 6 vollt or 8 volt
Posted by Bob M on September 20, 2007 at 08:01:26 from (151.190.254.108):
In Reply to: Super A 6 vollt or 8 volt posted by ram4wd on September 20, 2007 at 07:41:27:
I agree with Bob below. Installing an 8 volt battery is only a "band aid" fix for other underlying electrical problems. Better to spend the extra cost of the 8 volt battery to get the electrical system into 1st class condition.
Also.... With the 8 volt battery you will find it more difficult to keep it charged - especially if your tractor is used lightly/infrequently. And if you use the lights it will shorten their life (they will burn brighter however!)
