Re: Super A 6 vollt or 8 volt
Posted by John T on September 20, 2007 at 10:14:28 from (66.244.83.147):
In Reply to: Super A 6 vollt or 8 volt posted by ram4wd on September 20, 2007 at 07:41:27:
Also, if you start messin with that oddball NON factory cobbled up system in addition to oddball batteries, the points (if a coil ignition) will burn up quicker and likewise, the lights unless ballasted. Much bigger n way harder to crank John Deere A's n Farmall M's etc could be started with 6 volts so fer sue that Lil A can. I also like 00 Gauge Battery n Starter n Ground cables on 6 volt systems to lessen potential cable voltage drop.
John T
