Re: Stuck MD ??? Advice?
Posted by old on September 21, 2007 at 11:01:35 from (4.244.218.156):
In Reply to: Stuck MD ??? Advice? posted by Andy in Ohio on September 21, 2007 at 10:04:15:
Pull the spark plug out and switch it to the start possition on the levers so as to open up the spark plug to the cylinder. Then fill it with what ever but if it was my machine I would use tranny fluid before I would use PB. I would also try to blow some compressed air into the cylinder to make sure it doesn't still have water in it or you will be wasteing your time because any type of oil floats on water
