1943 Farmall H value?
Posted by MichaelNEIowa on September 21, 2007 at 21:05:34 from (65.101.140.103):
I"m looking at an old 1943 H. 6volt, straight tin, 1 set of wheel weights, lightbar toolbox, lights, swinging drawbar. Has the huge shock absorber seat, no belt pulley.
Paint is mostly gone with surface rust, tires hold air but will need replaced. Front rims shot. Seems to run good.
What"s this worth?
