Re: cub pto lever to bushing(clutchdog)
Posted by Bigdog on September 22, 2007 at 04:18:15 from (71.64.19.70):
In Reply to: cub pto lever to bushing(clutchdog) posted by GRIVV on September 21, 2007 at 19:10:19:
If you have already secured the quadrant, loosen or remove it and it will give you a little more range of movement. Also, I find it easier to maneuver if the entire backplate is removed instead of just the pto shaft and bearing retainer.
