Re: 12v gen wiring diagram?
Posted by RustyFarmall on September 22, 2007 at 05:05:25 from (66.43.253.55):
In Reply to: 12v gen wiring diagram? posted by Mike CA on September 21, 2007 at 21:09:24:
Basically there is very little difference between 6 volt and 12 volt generator systems. The one big difference is that the 12 volt uses smaller battery cables, but everything else is pretty much the same. The location of the VR is dependent on the year of the tractor. The earlier models mounted it on top of the generator, the later models had it mounted on the rear gas tank support. I have one H with the VR mounted in a "custom" location, and it works, so I'll leave it there.
