Farmall H 12V Generator not charging
Posted by Andy Motteberg on September 23, 2007 at 18:52:06 from (4.143.219.41):
Hi,
A while back, I bought a 12 volt generator for my 1943 Farmall H because I converted it to 12 volts. I wired the entire tractor exactly how it said in Bob M's wiring diagrams. The tractor runs, but is NOT charging. I was told by the person I got the generator from that it came off his great running Farmall M and that it charged very well. The amp gauge DOES work. The generator has a cut-out on it. I thought maybe the points in the cut out were dirty, so I sanded them and still, no charge. Another question is, the headlights won't work on Dim lights or Bright lights. The lights have new 12 volt bulbs in them. My H has the 4 position light switch (high charge, low charge, dim lights, bright lights). I used 10 gage wiring for the generator and lights. The H runs nice, but no charge. What should I do about this? What should I check? I was also told the headlight switch was good. If you could help me with these problems, I'd appreciate it!!
1943 Farmall H
c-152 4 cyl engine
12 volt generator w/cutout
H4 magneto
Thanks,
Andy Motteberg
