Re: Haveing MAG Trouble on MY A
Posted by Karl Hamson on September 23, 2007 at 19:45:29 from (24.108.34.216):
In Reply to: Re: Haveing MAG Trouble on MY A posted by ScottyHOMEy on September 23, 2007 at 17:17:26:
I pulled the same stunt with my C trying to get at the points(did it later with the governor as well). I spent the best part of an afternoon crawling under the tractor with a flashlight, then out again to nudge the crank handle another degree or so. I never did find the timing mark.
I resorted to a piece of bent fence wire in the plug hole after the thumb in the hole routine. Much simpler, especially if you are by yourself.
Karl
