Re: Haveing MAG Trouble on MY A
Posted by HENRY E NC on September 23, 2007 at 20:16:15 from (216.119.7.12):
In Reply to: Re: Haveing MAG Trouble on MY A posted by csmeyers on September 23, 2007 at 16:55:39:
This io what I did---- Take plug from # 1, take valve cover off to see the rocker arms move, turn crank until the piston cpmes to top, you can see with a flashlight, also whn the rocker arms quit moving. then I got under the tractor and found the marks which are hard to find to confirm TDC. The install the mag with the rotor poiting to # 1, Top right facing the front. Took about 10 minutes and required a friend to help.
