Posted by Owen Aaland on September 25, 2007 at 00:24:58 from (65.165.246.209):
In Reply to: 1468 international posted by molinebob on September 24, 2007 at 16:29:53:
Rated about the same horsepower as the 1466 but does not have as much torque. Better fuel economy than the six cylinder. Designed to us ether assist for starting in temperatures below 70 degrees. Start cranking the engine and when it gets to cranking, speed press the either assist button. Hold the button in after it starts to run until the white smoke clears up. It can take a couple of minutes in cold weather.
To aid in keeping the engine under enough load to keep it from smoking when lighly loaded, fuel is sent to only four cylinders, two on each bank. When the engine load reaches about 20 percent the other four cylinders start to receive some fuel deliver. This percentage increases until 80 percent load. From 80 to 100 percent load all eight cylinders should be receiving equal amount of fuel.
The engine does not use sleeves but can be rebored. The crankshaft is not regrindable. Later engines had a little higher comprression and used the opposite four cylinders when running in the reduced fuel mode.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror
... [Read Article]
Latest Ad:
[More Ads]
