Posted by SproutW on September 25, 2007 at 05:31:59 from (64.4.164.155):
In Reply to: Re: F-20 Draw Bar Mounts posted by Curtis Vaughan on September 24, 2007 at 16:51:47:
Nothing held the brake lever except rust. I thought it had a key or cotter pin but nothing present. Just has a cotter pin on the side to keep it from moving side to side.
You have to take off the brakes and pull the brake rod out through the brake housing. The brake lever is attached to the brake rod. Make sure you have a rubber mallet because the brake cover is usually rusted on. Let me know if you need more info.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
